RE: Upgrading from Creo 2.0 M010 to M020
PaulSpencer
1-Newbie
Hi
I'd like to upgarde from Creo 2.0 M010 to release M020 - ho do I go about doing this?
In anticipation
Paul Spencer
2 REPLIES 2
Always uninstall all previous versions including Quality Agent then do a clean install. You should be able to use your existing Creo 2 product code.
Hang for until I send you M030 download link, the config.pro has been updated to sort a problem with WindowsXP 32 bit. The Choice DOS command got missed off.
OK Tim , will do. Any time scale to this?
