Reading Value from Temperature Sensor which is on raspberry pi through TW C SDK
shiremath-2
We referring the below link and attached TWC_Agent_C _SDK to read values from temperature sensor (Sensor used is DHT11 – Port used GIOP17) which is on raspberry pi Model B+. http://www.thingworx.com/developer/device-kits/raspberry-pi After following the above link and after configuring as it is mentioned there, we are not getting temperature value to Thingworx thing. Kindly let me know if we are missing the somewhere like config settings. Or Do we need to do anything extra process to fetch the values.
Please below images for more details:
Error Log File:
Agent Properties  file for configuration:
Thingworx properties managed bindings:
Shantha
0 REPLIES 0
