SOAP XML Parsing
rkrishna1
1-Newbie
SOAP XML Parsing
Could some one help me in parsing below soap response while calling service:
<infasoapns:Envelope xmlns:infasoapns="http://schemas.xmlsoap.org/soap/envelope/" xmlns:infawsdlns="http://schemas.xmlsoap.org/wsdl/" xmlns:tns="http://www.informatica.com/dis/ws/">
<infasoapns:Body>
    <tns:OperationResponse>
      <tns:SNA_SERVICE_RESPONSE>
        <tns:STATUS>Failure</tns:STATUS>
        <tns:STATUS_CODE>000002</tns:STATUS_CODE>
        <tns:STATUS_MESSAGE>SGTIN_NOT_EXIST</tns:STATUS_MESSAGE>
       <tns:PRODUCT_DESC/>
       </tns:SNA_SERVICE_RESPONSE>
     </tns:OperationResponse>
    </infasoapns:Body>
</infasoapns:Envelope>
How can i get values or store into infotable. Any help would be appreciated.
2 REPLIES 2
adrianpet
(To:rkrishna1)
     Can you show me the service that you've made in order to obtain the values from the SOAP?
     Basically you'll need to create a service in which you will set the BaseType in the Inputs/Outputs tab to be InfoTable(you may need to set a DataShape for your parameters) and the infotable Type should be Just Infotable, but first I would like to see the service that you have created for this.
Thank you,
Adrian
Hi Rajesh,
did you see this posting: Regarding SOAP based Webservice Call​ and specifically the answer from Pai Chung. It points out how the XML that is returned by a SOAP call can be easily parsed with E4X. You can also use for loops with it, e.g. (based on Pai's example):
// this is what Pai referred to:
// var itemKey = xmlDoc.::Body.::GetTopTenPartsResponse.::GetTopTenPartsResult.::JsonRecord.::item.::key.*::string;
// let's assume GetTopTenPartsResult has multiple JsonRecord sub-elements then your code could look like the following:
//initialize your infotable
var myInfoTable = ...;
for each (var entry in xmlDoc.::Body.::GetTopTenPartsResponse.::GetTopTenPartsResult){
     var itemKey = entry.::JsonRecord.::item.::key.*::string;
     // now use this value with an object for an InfoTable row:
     var newRow = new Object();
     newRow.key=itemKey;
     // ... assign other values from XML to object properties
    myInfoTable.addRow(newRow);
var result = myInfoTable;
