I am unable to uninstall PTC Creo Simulate / Parametric / Layout and Direct 3.0 Datecode [M030] Version. When I press the uninstall button a little window opens up and it shows a red cross only. I am just able to close the windowm, but nothing happens...
How do I uninstall these programs ?
Thank you
in the past I used the following procedure:
Martin Hanak
Martin Hanak
