Using with RDP
brianv94
2-Guest
Using with RDP
I have a Mac and the only way to take this class was to install windows in a VM , when I RDP to the windows machine I get an error about licensing. How can I use the student version on my VM? Can it be converted to the floating license?
I think Creo via RDP works only in case that floating license is installed on remote machine.
Student license is locked.
I guess that you can use Teamviewer to access remote machine and use locked license.
Martin Hanák
paz
7-Bedrock
7-Bedrock
(To:brianv94)
An alternative solution would be to purchase and use Parallels Desktop. Creo Parametric runs well on windows installed on Parallels, no RDP required.
