What in devils name does this mean?
ptc-2202650
I have just install this software I'm folow the instruction it installed, howver I'm getteing this error?
As your license file is locked to the network card used during install, this problem may be solved by changing the state of your Wireless and restart the program. If you licensed your Creo 2.0 with WiFi on/off you will need to use it with the same setting.
