Will the Velocity Vortex field models be available in Creo?
SOLVED
Newbie
This question is Not Answered.(Mark as assumed answered)
Linda StewartCopper
If so, when are they expected to be available on the download page?
Linda
Re: Will the Velocity Vortex field models be available in Creo?
My apologies. I should have announced the availability of the field models here. They are available for download and can be picked up on the Software page of the PTC FIRST portal @ Software | PTC.
For those who need it now, the direct download link is http://apps.ptc.com/schools/FIRST/FTC_Field_2016-17.zip
Scott,
Thank you for the link.  I downloaded the parts KOP and i am running into regeneration issues with few assemblies with missing parts.  An example of them is the wheel assembly is missing quite few parts (Either the part files were renamed or an incorrect part file name was used in assembly).  Do you think there is a corrected version of tetric KOP?
Bhaskar
This discussion is about the field CAD models, but it sounds like you are asking questions about the general KOP CAD models. Exactly which model are you having problems with?
