can't see any side on the sketch
SOLVED
Newbie
after i download the creo2.0(for student) , i cant see any front or top or right one the screen, i check all the options, it all right , but i cant choose any side or sketch place , even i choose top at will , still cant sketch or do anything , i try to download again , but still the same , just like the photo i upload , that is i prt screen, hope someone can hlep me , it will grateful .
Re: can't see any side on the sketch
This issue is caused almost always by out of date graphics drivers. Usually updating them should fix this right away.
http://communities.ptc.com/videos/4255
Above is a video on the topic, let me know if you have any questions. There are also other tricks we can try, so let me know if that does not work.
I've moved this discussion into our community so our Academic team can take a look and provide you with some support.
Welcome to PTC Academic!
