Is it possible to have commercial version and student version on same computer., i am a mentor with First Robotics Team and it would be help when i am working with the students
I'm assuming you are referring to Creo Parametric. The software is the same, its only the license that's different. You can install the student licence on your work computer assuming it is the same version the kids are using on the team. Creo has always supported the configuration of multiple licenses.
Hey Kevin Maltzahn - I've moved this discussion into our FIRST community so our team there can answer this question.
