I haven't any problem with the install but the program will not run after the splash screen appears then disappears. I'm running WF4.0 without any problem but can't seem to get Creo pro 5.0 to run. I am DL WF5.0 again and see if it may be the version that I downloaded the first time.
Thomas Felty
Mark Fischer helped out on this one. It was a graphics card problem. Mark wrote a line in the config file and now it works great.
Thank you Mark
