Hi when configuring standard and units of measure, I get an error message saying the file(s) cannot be found. This is directly after installing the Academic Edition of Creo 2.0 and running the configure.bat as an admin. I also went back and installed the MKS option after thinking the files may be contained in there.
Cheers
George
Problem resolved - I set the common files folder to full control in security and set my user to full control and the problem was solved.
George
