how do I change the language?
privera
1-Newbie
I have a due project and the language is in Spanish I wish to change it back, help me please.
1 ACCEPTED SOLUTION
  1. default Creo language is English, this language version is always available
  2. other language versions are available only in case that they were selected during Creo installation
  3. language setting is performed via parametric.psf file located in Parametric\bin directory in Creo installation
Add the following line at the end of parametric.psf file, if you want to use English version of Creo:
ENV=PRO_LANG=english
Languages supported:
LanguageEnvironment Variable Name
Chinese Simplifiedchs
Chinese Traditionalcht
Frenchfrench
Germangerman
Italianitalian
Japanesejapanese
Koreankorean
Spanishspanish
EnglishC or english
Russianrussian
See also:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS110907
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS147730
MH
Martin Hanák
1 REPLY 1
Frenchfrench
Germangerman
Italianitalian
Japanesejapanese
Koreankorean
Spanishspanish
EnglishC or english
Russianrussian
See also:
MH
Martin Hanák
