i have an issue when i launch setup.exe
tomvv74
1-Newbie
Hello.
i have an issue, when i launch setup.exe they are nothing and i launch it with administrator mode...
do you have an idea?
3 REPLIES 3
1] Did you unzip downloaded 4Gb zip-file before starting setup.exe ?
2] Try running setup.exe on different computer.
3] What OS is installed on your computer ?
4.] What Creo version are you installing ?
Martin Hanák
Sorry, I did not ask this question - but I have the same problem.
I have downloaded and unzipped the Creo 6 student version.
Unfortunately I cannot start the Setup.exe file. First the normal Windows prompt appears asking if you want to install it. But then nothing happens.
I have Windows 10 Version 1909, 64bit
What can I do?
What can I do?
See my reply in https://community.ptc.com/t5/PTC-Academic-Program-Discussions/Lauching-setup-exe-and-nothing-happens/m-p/655464#M11198 discussion.
Martin Hanák
