licens error
gabriel_20
licens error
hi!
just downloaded creo 6.0 (student) and when I start the program an error messages appears (shown in the attached files). Any suggestions is much appreciated!
1 ACCEPTED SOLUTION
3 REPLIES 3
gabriel_20
(To:gabriel_20)
update:
I think i found the problem. The license key I was given (BE500806EDSTUDENTEDK12 )is for creo 5.0. What do I need to do to get the key for 6.0?
gabriel_20
(To:VladimirN)
Spoiler
Solved!
Thank you, if somebody gets this problem run setup.exe and press "-" on the license key that you dont want to use.
