Hi.
One year ago I installed CREO 2.0 as a drawing tool in studies of mechanical engineering at the URV (Universitat Rovira i Virgili). Now the license has expired. I have the possibility to extend this license ??
Or should I BELIEVE uninstall and reinstall again ??
Thank you
Hi Emilio,
Please see the below guide to fix the problem that you are experiencing:
http://apps.ptc.com/schools/references/relicense_creo2_student_uni.pdf
Please let me know if you're still experiencing an issue afterwards!
Hi Emilio,
