locking unlocking constraints on a sketch
Regular Member
I am using a great book, Parametric Modeling with Creo Parametric by Randy Shih.
In one section (pg. 4-8), it talks about locking and unlocking constraints on a sketch.
The book tells that by right clicking we can activate lock or unlock given constraints (L1, H, V etc.)
Well, this would be great if I could get it to work, but I don't seem to get the same menu options when I do this.  I also do not see the red circles that the book talks about.
Is there some setting or version of Creo that doesn't allow this?   I am using  Creo 2.0 academic version.
In general, it would be very nice if there were a way to see the pre-existing constraints on a drawing sketch.  I have never been able to see this until I try to modify a sketch and it give me the violation window, where I then must choose to delete an existing constraint or live with the sketch as is.
Is there any way to see and edit the existing constraints on a sketch?
Thanks.
Tags (2)
Welcome to PTC Academic!
