sprockets for AndyMark chassis
rhelber
Is there a way to get a CAD or step file for PTC Creo of a sprocket that will go in an AndyMark chassis?  Or, do I have to make one?  Making a sprocket seems complicated.  If I can't get a file, is there a good tutorial for making a sprocket?
1 ACCEPTED SOLUTION
sm
1-Newbie
1-Newbie
(To:rhelber)
Courtesy of FRC Team 525 and Thomas Ore
5 REPLIES 5
sm
1-Newbie
1-Newbie
(To:rhelber)
Model it as a disk for now and I'll do what I can to get you a comprehensive set of sprocket models.
rhelber
(To:sm)
Thanks!  Okay, I'll use disks.  I found a sprocket in a step file of the old AndyMark chassis.  But my team is using sprockets with a different number of teeth.  I like PTC Creo, it runs better than Autodesk Inventor on old slow laptops.
rhelber
(To:sm)
I found sprocket CAD files at VEX Robotics:
http://www.vexrobotics.com/25-sprockets.html
Thanks!  I'm all set.
sm
1-Newbie
1-Newbie
(To:rhelber)
rhelber
(To:sm)
These files are perfect.  Much better that the random .step files I found on the internet.  Thanks FRC Team 525!
