wont install 3.0
Newbie
wont install 3.0
this is the file i downloaded....
MED-100WIN-CD-400_M010_Win64
I extracted to the desktop. I disabled the firewall and A/V. I ran setup as admin.
I receive 2 errors that both read ......
"The Procedure entry point ?in@?$codecvt@DHH@std@@QBEHAAHPBD1AAPBDPAD3AAPAD@Z could not be located in the dynamic link library C:\Users\Ryan\Desktop\cad\pim\i486_nt\baselibmt.dll"
Windows 8. 64 bit.
Re: wont install 3.0
Hi Ryan,
This issue is observed while installing Creo 3.0 in some cases and is being reported to R&D. The current available workaround is as mentioned below:
  • Copy Creo 3.0 installation files from disc on local drive of the computer
  • Copy all the .dll files from <CD image>\pim\i486_nt folder to the main <CD image> folder having setup.exe
  • Run the setup.exe
Amol Lungare
Technical Support Engineer
T 800.477.6435 (U.S)
E -
PTC.com
Welcome to PTC Academic!
