12/1 Weekend Maintenance
Ruby IV
Problem seemed to be solved for a while but quite now it again took minutes to log in
36 REPLIES 36
Re: s l o w
Again! Problem not solved!
I was just about to cancel the process when finally after some minutes the login was successful.
It looked to me as if support.ptc.com was the problem and not lithium, but I may be wrong about that.
Re: s l o w
In case anybody cares - just now it took me 3 minutes and 20 seconds for being back to the community page after entering my login data at support.ptc
Problem not solved 😞
Re: s l o w
I am also seeing the problem again. I tried both Mozilla Firefox and IE 11. This reply was done via email and just as I was finishing, the login was successful on both.
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
Re: s l o w
To echo others comments, it took over 2 minutes this morning from submitting my credentials to seeing the page I was headed to (private messages).
LinkedIn
Re: s l o w
I just logged in.  Took me 2 minutes and 15 seconds.
There was some sort of maintenance done over the weekend. Did that get done correctly?
https://community.ptc.com/t5/PTC-Community-Announcements/PTC-Community-Read-Only-State-December-1st-...
Re: s l o w
@Dale_Rosema
Yes, we were included in the "shutdown" while the eSupport team had some backend changes.  As far as I know, that maintenance activity went as expected.  I have an open ticket with Lithium regarding my announcement area on the community.  This is why I haven't removed the message yet.  Thank you for checking in!
Re: s l o w
Funny thing is I never saw the message (other than the posting through PTC Community Announcements) until I just went to flag a MathCAD question posted in the wrong area. I seldom if ever go to the PTC Community home page so I never saw the "flag" / announcement.
Re: s l o w
Subcribe to the announcements board https://community.ptc.com/t5/PTC-Community-Announcements/bd-p/community_announcements
Its the only way I know since I pretty much only interact via email.
Steve Williams
Re: s l o w
Jaime,
after weekend maintenance login to support.ptc.com takes 2 minutes 15 seconds. Please can you forward this "message" to appropriate PTC department ?
Martin Hanák
Re: s l o w
@Jaime_Lee, login today - 2 minutes and 8 seconds.
Re: s l o w
Same here, 2:12.  That is faster than it was a week ago, but still far too slow.
LinkedIn
Re: s l o w
@TomU @dgschaefer
Are you referring to login at community.ptc.com or support.ptc.com ?
Re: s l o w
I was coming in from the community, but don't they both use the same login?
LinkedIn
Re: s l o w
So, I logged out of the community and then clicked login to check the address of the login page.  I was logged back in immediately, automatically.
So I clicked log out again and went to the support page (support.ptc.com) and when it loaded I was already logged in.  I logged out again and was presented with a different log in page.  That login worked fine, but considering how logging out didn't seem to actually log me out, I can't say for certain that it's working correctly.
Returning to the community it showed me as logged out.  Clicking log in resulted in being immediately and automatically logged in.
Not sure if any of that helps the slow login issue, but I thought I'd report my findings.
(Separate from the slow login issue, personally when I click log out I should be logged out and have to re-enter my credentials to get back in.)
LinkedIn
Re: s l o w
Attempting to log into the community redirects to this page:  https://support.ptc.com/appserver/common/login/ssl/login.jsp?
To access support I use this favorite:  https://support.ptc.com/appserver/cs/portal/  It also redirects to the same login page as the community:  https://support.ptc.com/appserver/common/login/ssl/login.jsp?
If I log out of both the community and support and then attempt to log back into either one, it takes 2 minutes and 9 seconds before a response is received.  Once I'm logged into one I can access the other without having to login again.  (There is really only one login for both.)
Re: s l o w
Seems like maybe it's related to a redirect:
Re: s l o w
Thank you all for your feedback.  A ticket is open with the internal PTC IT team to research this!
Stay tuned to this thread for updates.
Re: s l o w
did you recive some feedback from IT team ? It is really annoying to wait 2 minutes to login ...
Martin Hanák
Re: s l o w
Wish it would only take 2 minutes as it used to be a few days ago!
At the time I am not able at all to login to from the community page - it times out.
But as a workaround I can login to support-ptc without problems. When I then go to the community site I am logged in. Annoying!
Re: s l o w
I am sending HAR file generated from Chrome.
2018-12-10: I removed an attachment, because it contains secure information (eg. username, password, company name) written in plain text.
Martin Hanák
Re: s l o w
@Jaime_Lee
Any news about this from your IT team? Its now about two weeks and the problem persists. At least since december first its a PTC only problem and seems not to be related with Lithium.
The same login delay occurs if we just log in at support.ptc.com.
Its incredible that a problem like this could not be fixed within two weeks!
Re: s l o w
@Jaime_Lee
Hi Werner,
please can you test following procedure ?
1.] launch browser (IE11, FF, Chrome)
2.] enter following URL into address bar
https://www.ptc.com/en/support/login?returnUrl=%2fen%2fsupport
3.] enter username + password
Note: The above procedure enables me to login immediatelly.
Martin Hanák
Re: s l o w
I'm seeing the same behavior.
Fast:  https://www.ptc.com/en/support/login
Slow:  https://support.ptc.com/appserver/common/login/ssl/login.jsp
Unfortunately both "support.ptc.com" and logging into the community redirect to the slow page.
Jaime_Lee
Community Manager
(in response to TomU)
Re: s l o w
Internal PTC is still investigating the issue.  Lithium reaffirmed that it is not on their side.  Will continue to check in with IT.  It seems that @TomU found a work around.
Re: s l o w
I am with Tom on this one.
I can login quickly with his fast link.
With the slow link I ALWAYS get a time out on the connection.
Could it be the jsp page code?
Re: s l o w
Problem with 2+ minutes login delay seems to be fixed finally
Re: s l o w
@Werner_E thank you for letting us know that it seems resolved.  We appreciate all your updates.
Re: s l o w
I can also confirm that https://www.ptc.com/en/support gives a quick login.
After this I still have to press login at the community page but there at least is no further delay.
It would have been a quick workaround to change the redirection from support.ptc.com to ptc.com/en/support for the time the problem is being fixed.
Unfortunately PTC IT team decided to do, obviously, nothing for the last two weeks - incomprehensible!
