Add Subcategories
hheinze
Add Subcategories
Also add a subcategory. For instance has Cero many stuff that is separated.
I am using very often help regarding MACHINING/Manufactung.
Now I use the Filters, but still.. much Stuff I do not need is showed there.. because I can not filter for only machining/manufacturing.
So a category with all those sub-categories that are in the "Help" already could also applied here.
Look here:
It is all under Creo right now.. And then there would be still many subcategories..
BUT if you use less than 6 phrases, it really uses an AND concatenation.
if you put it into: >"this would" machining< it is looking for the exact phrase AND machining in one thread.
AndrewK
Community Manager
(To:hheinze)
Hi @hheinze
I'm not sure if this is what you are looking for exactly, but we do have multiple Creo Parametric boards including one for manufacturing. These boards are further subdivided using labels which can be used to filter the board or search results. You can also subscribe to a label. If there are labels you think should be included let us know.
hheinze
(To:AndrewK)
Thank you! Can you please post a Link? That makes it easier.
Ahh, I found it:
https://community.ptc.com/t5/Manufacturing-CAM/bd-p/manufacturing
I never used this Menu Button before..
But anyway: I prefer to use the search function inside here:
https://www.ptc.com/de/support/search/#q=%22Maximum%20sequence%22
It is the support and thats is the place where I expect (and mostly got) the best answers. Also is that the place where the programmers and developers answer instead of the community.
I am willing to help where I can, but it is not THE WAY to let the community do everythig.
Many things are implemented but unknown, other things have to be reprogrammed.. and that is why I think PTC has to know, answer and also try to get better..
hheinze
(To:hheinze)
But.. I hit too fast SOLVED.
It is not solved, I know that board.
it is where people help people.
The search function that is mentioned earlier is missing the filters.
