I tried updating the following document with some additional information:
Although I could edit it the website wouldn't let me save it and got the following error:
Yet, when I copied and pasted the contents into Word and count the characters I get
When I look at the "source code" in HTML I get
Based on this I am thinking that it is rejecting my edits due to HTML being ridiculously verbose. Is this intended? Can the limit be increased? Can you have it count text only instead of HTML code? Anything else that can be done?
It is noteworthy that I only added a few lines and it was otherwise as the post existed prior to me touching it today.
Hi @LawrenceS, unfortunately you are correct, and HTML is counted towards the limit. We may be able to have this limit increased, but it isn't an issue that comes up often, so we haven't pursued that before. I will bring it up with the community team. In the meantime, there is a way to circumvent this limit. I'll message you with the details.
@LawrenceS just wanted to give you an update. We had the character limit raised substantially, so this shouldn't be an issue in the future.
Thanks again for your help with this @AndrewK!
