Cannot submit product ideas
346gnu
Every time I attempt to post a product idea I get ...
correct the highlighted errors and try again.
  • Post flooding detected (community received posts of a unique message more than 1 times within 3,600 seconds)
4 REPLIES 4
346gnu
(To:346gnu)
It would seem that not adding a 'tag' causes this
AndrewK
Community Manager
(To:346gnu)
Hi @346gnu . Do you mean not adding a label? Labels are required to post and will cause that "correct the highlighted errors and try again" message. Let us know if you have any more issues.
TomU
(To:AndrewK)
@AndrewK,
Seems like he's hitting the other error message.  If he's getting it when forgetting a label, others probably are too.  Might want to check the error message processing order on the backend.
Dale_Rosema
(To:AndrewK)
I think I saw something similar to that once when I tried to post 2 or 3 different things within a short time span. Could that be the issue?
