Would it be possible to add another header/filter underneath the group sub-heading? Sometimes posts are moved from one category to another and may get buried in the transition if they are 5+ days old.
Hi Dale,
Unfortunately, that's not possible with the API available to us for customizations. However, there is an unread topics page you can reach from each board.
Is that a moderator setting? I am not seeing it?
I need to test it out to be sure, but I suspect it is the difference between posts and topics. The component shows unread topics meaning an entire conversation. If you have seen a topic, it won’t appear on the unread topics list. However, if there is a new reply to that topic that you haven’t seen, it will show up in the count of new posts. I will test this out to confirm how it works and let you know.
Maybe update it to be unread posts.
