When orchestrating a search within the Community and filtering by author is desired, would it be possible to make the individual searcher the first thing in the drop down unless you start typing in the keyword box? Frequently I am searching for something I have posted in the past and cannot remember what the solution was and I am trying to find the post that I had originally created.
Hi @Dale_Rosema
I made this update today. Now if you are logged in your name will show under the author dropdown as seen here.
Hi @Dale_Rosema
I think we have talked about doing this before. I will try to look into it in the next few weeks. It is probably something we can do.
Hi @Dale_Rosema
