Is there an option we can toggle to permanently hide the community tip banners that now appear at the top of the boards?
Currently, there is not, but it is something we are considering. However, at the end of the month we will be turning this off for higher rank community members and it will only appear to new members going forward after that. So, either way you won't see it for long.
