There was a topic that showed this with an accepted solution.
https://community.ptc.com/t5/Welcome-How-To-s/Finally-Mark-as-read-is-available/m-p/475449
Was this for an individual topic or is there a way to do this in bulk. i.e my Creo Modeling Questions shows 106722 new post. All of the "new" ones are extremely old questions from the migration. Is there away to go in and en mass mark these all read?
Hi Dale,
if you go up one level (from this topic to Community Feedback) in the right upper corner move the mouse over Options and then select Mark all as Read.
Hi Dale,
Now at least if someone else searches on it. There will be an explanation of how to do it.
Dale
