I have been using the PTC Knowledge Base for almost two years now. I was wondering if there is a mechanism to provide feedback on articles, other than the one provided on each article page. Specifically a user, customer or VAR advisory group on improving the KB.
That group is really the best place for general observations. Some past examples:
Best place to go is here: https://community.ptc.com/t5/Discussions/bd-p/PTCeSupportHelpDiscussions
The people in charge of the knowledge base monitor this board.
Thank you. Another well hidden resource : )
thank you for getting involved.
Another way to convey your feedback is to use the "Was this Information Useful?" box from the thumbnail called Feedback on the top left of an article.
Your feedback will be about only and only the article that you current read, in order to make your feedback "itemable" and the authors of the article will be notified.
A process then is started internally to keep the authors accountable.
Yes, I do that extensively, and I do get responses from the author. However this does not address the pet peeves I see in the articles repeatedly, which makes me curious about the process in general.
I will create a separate post there with my suggestions.
