Username changing randomly
Patriot_1776
Anyone else seeing this?  Their username randomly changing to some text string?  PTC STILL doesn't have a fix for this.
4 REPLIES 4
Only time I experienced anything like this was when we were first relocated onto whatever this forum is (Lithium?). I do note all the new folks seem to have <LETTER><LETTER>-long string of numbers as their probably default ID. Maybe your name changes a lot because of the troubles you've had with wacko(s) in the past? Maybe it's a side effect of whatever tactics the use to protect you? Dunno.
Patriot_1776
(To:KenFarley)
'Sup Ken!
Yeah, sadly they are still around, and, maybe it is part of the new "security", but, man, it's annoying...  Glad none of you guys are experiencing it though!
AndrewK
Community Manager
(To:Patriot_1776)
Hi @Patriot_1776 sorry you are still experiencing this issue. I will check in with the team investigating this to see if they have an update and let you know.
Patriot_1776
(To:AndrewK)
Thanks.  Tre annoying.
