Before the latest change to the Thingworx developers part of the communty you were able to reach the IoT Tips section.
Maybe I am just blind, but I just can't find it.
How can I navigate to this section now?
I thought it might be through here:
But can't find it.
Or here:
But no luck.
Is it designed so that you have to use the search function?
Jens
Hi @jensc
Thanks for pointing this out and apologies for the trouble.
Here are a few ways:
You can bookmark this link:
https://community.ptc.com/t5/IoT/ct-p/IoTAR
From the menu top left:
Then
We will soon redirect the icon you see from the home page to the link above.
Hi @jensc
Then
Hello @olivierlp
Thank you, I knew there had to be something I missed!
It seems like the thingworx product forum:
once again leads to the "correct" URL:
Jens
