Hi Team,
We are facing an issue with when we try to run a task in arbotext it fails to start with below error.
[A11682]Cannot execute the "set javavmargs" because JVM has been loaded.
I checked regedit -> STARTUP_PATH. The value is set to "C:\Program Files (x86)\Arbortext\Editor60\bin\x86\editor.exe -nojvm".
Can you please help.
Ronak
Have you called Support?
