Hi All, I am pretty new to Arbortext and I am facing a problem. I have a couple of projects under a root folder and each project has multiple topics. I created a new project and I wanted to 'Check in As' the topics from the projects to the new project. However, it has really become a tedious task as I have to manually 'check in as' each topic one by one. Is there any way I can manually 'check in as' multiple topics at the same time?
What I am currently doing is that I first view the topic and then use the option SDL Live Content > Check in As.
Any help would be hugely appreciated.
Thanks in advance.
Avishekh
Hi Avishekh
That sounds like an SDL Live Content issue. Check with your rep or SDL technical support.
Liz
The Global Summit is the largest annual gathering of PTC/USER members—featuring a jam packed agenda of content and opportunities to mingle with and learn from your peers. Join us in Las Vegas!
