Wants to change the association between WT part and EPM document
ptc-46425
2-Explorer
Sir,
let me explain the senario,
First we created EPM document using java program and created WT part using “windchill wt.load.LoadFromFile –d c:\PTC\dummy\part.xml - CONT_PATH /wt.inf.container.OrgContainer=AL/wt.pdmlink.PDMLinkProduct=H4” script(OOTB Script).
To make connection between WT part and EPM document we used
windchill wt.load.LoadFromFile –d c:\PTC\dummy\partepmlinkloader.xml” Script.
Now the problem is WT part and EPM document associated under context relationship. Because of that not able to change the revision ,state for the WT part.
Normally WT part and EPM document should have owner association. So we request you to suggest how to change the association from context to owner. Matter is urgent we migrated almost 17000 parts.
For any clarification please call me at 9841723216 or mail to vsiva.alvvc@ashokleyland.com
V. Sivakumar.
Hello
Can you give an example of the content of the 2nd xml file ?
cause I don't know if there's an OOTB script to create owner link
content link is a "basic" and easy to create describe link
But owner link is more complicated, as it is a "double* link (BuildRule + Buildhistory) and it synchronise and drive the WTpart BOM
Anyway. you are able to import WTpart BOM with associated owner 3D CADDocs with the OOTB import/export tool.
regards
Gregory
This is the sample xml file.
<?xml version="1.0" ?><!DOCTYPE NmLoader SYSTEM "standardX20.dtd">
<NmLoader>
<csvPartEPMDocDescribes handler="wt.epm.LoadEPMDoc.createPartEPMDocDescribes" >
<csvfileName>FPartMigrationCheck.PRT</csvfileName>
<csvdocVersion>#</csvdocVersion>
<csvdocIteration>1</csvdocIteration>
<csvpartNumber>FPartMigrationCheck</csvpartNumber>
<csvpartVersion>#</csvpartVersion>
<csvpartIteration>1</csvpartIteration>
<csvpartView></csvpartView>
<csvpartVariation1></csvpartVariation1>
<csvpartVariation2></csvpartVariation2>
<csvorganizationName></csvorganizationName>
<csvorganizationID></csvorganizationID>
</csvPartEPMDocDescribes>
</NmLoader>
Yes this one is only to create content link .... not owner link ...
And nothing in the loader to create owner link...
