2015 FIRST World Championship Creo Modeling Challenge #5 - Production Model Drawings
sm
Creo Parametric CAD Modeling Challenge
For this fifth Creo Paramedic CAD modeling challenge, you will be creating a detailed drawing of a single part model. You need to know basic Creo Parametric drawing capabilities, along with some advanced capabilities to complete the drawing. It is a complex drawing to create and you will need to master Creo Parametric drawing annotations to complete it.
HINTS
  • Use one of the attached CAD files from FRC114 (STEP) and FRC4818 ‌(Creo) to create your drawing
  • Use of your own complex CAD files to create the drawing
  • Make sure you have configured Creo with the "Schools Configuration" to access formats, notes, tables, etc.
  • Use proper Geometric Dimensioning and Tolerancing (GD&T)
Sample drawing courtesy of FRC525.
Extra Credit
  1. Try different dimensioning schemes; regular, ordinate or hole charts
  2. Create detail views, cross sections and other details to document your model
  3. Add tolerancing to dimensions
  4. For Creo models, try using Show Dimensions as much as possible
0 REPLIES 0
