Trying to access the download and installation instructions for creo 3.0 and I'm getting a 404 error message.
Thanks for any help
Same problem here. When I try to follow the 2.0 pdf to get to the download page and then was gonna select the 3.0 to download, I get the error that I do not have "Customer Service Access". But the pdf is still needed to get the license key.
I have the same problem. I need the student license key/product code for Creo 3.0, which is in this pdf.
I need this key as well
As do I
Ditto
Having the same issue
I have the same issue as well.
Hi everyone-
The link has now been fixed! If you re-register, you will be taken to the Thank You page where the PDF link has been corrected.
We're very sorry for the inconvenience,
Stacie
Stacie,
I followed the new link and found the student key within. I put it in and got the "success" message. The program now opens and immediately a warning message comes up:
"License request failed for feature. Invalid feature name: [FEATURE_NAME]
Is this related to the key? Since the key wasn't initially working, I installed the program first and input the key afterwords. I am having the same issue on my laptop. Do I need to unistall/reinstall and start over?
Evan
Hi there-
Please see here:
http://communities.ptc.com/message/262529#262529
Let me know if that helps!
Stacie
I re-registered, but the 404 error is still present!
Regarding the 404 error- I would recommend clearing your browser's history, then trying the link below:
http://apps.ptc.com/schools/references/install_creo3_unistudent_standard.pdf
Hello Stacie,
I have still the same problem, how can it be fixed?
