About Error after Installing Creo 2.0 student edition
ptc-6360605
I have downloaded the creo 2.0 student edition, after installing when i open software the error is came, fatal error and software is not open ,
please anyone tell me what is the solution or how to fix it?
Foloowing snap shot is the window of that error
Hi All,
For any that may be looking at this post after the fact (such as via a google search), there is an updated solution available.
Please see the post below for more information on this...
http://communities.ptc.com/thread/56357?tstart=0
6 REPLIES 6
Hi Anup Patil,
It does not appear that a snapshow has been included? My recommendation would be to download the most up-to-date version (M110) from the below link and re-install.
https://support.ptc.com/appserver/auth/it/esd/academic.jsp
There was an issue on some computers with version M100 but that should be fixed in this latest release.
Thanks!
I have installed completed Creo M505 student with no errors,but when the first scense, i taked the screen photo for you to check,I can not access to use. ( as the attchment)
Please help me,
The trace creation timestamp is: Thu Jul 31 20:27:41 14
The executable build timestamp is: Wed May 14 23:43:16 14
The datecode is: 2014090
The pro machine type is: x86e_win64
The process ID is: 3936
The traceback type is : CRASH
Exception EXCEPTION_ACCESS_VIOLATION has occurred in the thread 4352.
Main Thread 4352
I'm not sure i'm uderdstanding the problem you are experiencing. Could you please elaborate for me please?
Have you found the solution? I have the same problem. I appreciate any help
HI Victor,
You can see informaiton on how to fix it below...
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS156839
If you would like more direct support or you are having trouble with the fix, please submit a support request using the below link...
http://support.ptc.com/appserver/wcms/forms/index.jsp?&im_dbkey=142574&icg_dbkey=482
Hi All,
