Adjusting Model Sizes/Scale?
sm
Received this question from an FTC team that created their lift sub-assembly from all custom designed parts...
When they tried to then include the lift onto the robot, it turned out that the lift is much-much bigger in size than the robot... so somewhere we messed up the dimensions/scales...
What can we do now? Can we re-scale the lift? so we do not have to redraw every part?
I how can I make sure that the dimension/units for the tetrix parts are the same than the ones I use for the custom parts?
The image shows a tetrix flat bar next to the bottom of our lift...
sm
(To:sm)
Yes, sounds like you have mixed units in the models. To confirm, open one of you new models and check the units; File, Prepare, Model Properties and pick change for the Units.
Could be that your model is MM and the values were input as INCH or vice-versa. In either case, an easy fix, just change the units and chose the appropriate scaling method from the Changing Model Untis window.
1 REPLY 1
sm
(To:sm)
