Hello everyone, I am using creo 10.0 and I am creating drawings for a step file, i was using a costume .frm file a3 size, i decided to change the format since it was too small, when i updated the format, i tried to organice the work space, relocating the views and its annotations, i can move the views but no the anotations, i made all the annotation from scrach again and keeps happening, i have to say the the annotations the arent following, are the annotations made to a sketch i created in the drawing module. if i create an annotation to the actual part, it follows. the sketch is properly linked to the view and the sketch follows the view when draged. but no the annotations. thank you very much
if you want attach line or note created in Drawing mode to some view, you have to select line or note and use Relate to View command.
