Blend problems
Anautics
Blend problems
I created a section of airplane wing from two sets of co-ordinates (top of wing and bottom of wing). Then, I imported this sketch of a wing into a part file in two separate planes. I then tried to blend the two sketches together but it failed to regenerate?
There were a number of problems.
No trajectory. A straight line between the two sketches
The sketches has overlapping geometry at the trailing edges. I dragged points slightly so they now shade in when the blue arrow is active.
There was a chord line in each profile sketch which I changed to construction.
Working file attached.
