Bubble Scatter Plot
Arshad_Ali
Bubble Scatter Plot
I want to make a bubble chart by by defining
i = 1 to 32
j = 1 to 32
so that 32 x 32 = 1024 points are generated
like as follows
(1,1), (1,2) , ... , (1,32)
(2,1), (2,2) , ... , (2,32)
(32,1), (32,2) , ... , (32,32)
the final output needed is
Hi @Arshad_Ali,
Thank you for your question.
Anurag
Hi @Arshad_Ali,
Anurag
(To:Arshad_Ali)
@Arshad_Ali
You don't say which software you want to use!??
In case you have Prime in mind, it would be best to post in the Mathcad section of this forum -> Mathcad - PTC Community
Here are two ways to achieve what you are asking for using Prime:
Prime 11 sheet attached
