I'm installing the PTC student edition. The installation of the licence fails every time no matter what I try.
I've cleared the license directory and tried again.
Over wifi (normal operation) I get the attached error.
If I disable the wifi and install it over fixed cable connections it gives me a succes but when I run it it,says that there are no licenses.
@TA_10125603 wrote:
hello Martin,
Installed the license .again over fixed connection (had to change the netwerk adapter because it showed the max addres of the wifi. Attached you'll find the license file and the ip.txt
Kind regards
Thomas
both files are OK.
ip.txt tells me that Ethernet adapter with MAC address 50-9A-4C-BF-63-BD is running.
BK600908EDSTUDENTEDUNI_license - kopie.dat.txt contains license code generated for MAC address 50-9A-4C-BF-63-BD.
License file enables you to run Creo Parametric 6.0 ... license name = CREOPMA_Student6
Suggestion:
ENV=PTC_D_LICENSE_FILE-=C:\PTC\my_Creo6_license.dat
ENV=CREOPMA_FEATURE_NAME=CREOPMA_Student6 ()
Have you followed this guide - "PTC Creo 6.0 - Student Edition - Quick Installation Guide"?
Yes I did. Did it multiple times, always same result over the Wifi the error and over the ethernet connection a success but it doesn't work.
my suggestion:
Open Command prompt window, launch ipconfig /all > ip.txt command and upload ip.txt file ... I will check its contents for you.
hello Martin,
Kind regards
Thomas
@TA_10125603 wrote:
hello Martin,
Kind regards
Thomas
both files are OK.
Suggestion:
Hello Martin,
Fixing the .psf file fixes the problem. Thx.
Kind regards,
Thomas
The license file got rejected in the virus scan. I think wrong extension. Changed it to .txt
