Calculation of weld design
Ravii
8-Gravel
I converted this Mathcad sheet from xmcd to mcdx. But now I've this error it is not calculating.
The file is attached. Please help me if know to fix this error.
2 REPLIES 2
MartinHanak
(To:Ravii)
(To:Ravii)
As Martin already mentioned, the 'syntax' for a a solve block was changed.
I don't know if it's still relevant after more than a year - anyway, in Mathcad, typing "Given" started a solution block and it ended with "Find", for example.
But in Prime you have to insert an (ugly looking) solve block from the menu to do so.
I think you are better off to ask questions about Mathcad or Prime in the forum here: https://community.ptc.com/t5/Mathcad/bd-p/PTCMathcad
