Can't activate purchased license
AK_10584883
1-Newbie
Hey! I bought the 1-year student license (PTC Prime 😎 this week, but I can't activate it. License request failes. See screenshot.
What do I do?
15 REPLIES 15
PTC Prime 8
1.] What Host ID is included inside license file ?
2.] Run ipconfig /all > ip.txt command in Command prompt window and upload ip.txt file.
Martin Hanák
The host ID don't match
Please send ip.txt file
Martin Hanák
Is that the notepad-file?
it look like you do not understand me. Just do following steps:
  • open Command prompt window
  • inside the window type ipconfig /all > ip.txt and press Enter
  • the command creates ip.txt file in directory shown in Command prompt window prompt
  • ip.txt file is text file ... it can be opened in Notepad
Martin Hanák
Sorry, I don't get it. I've typed the command and pressed enter but nothing happend.
the command created ip.txt file in MartinHanak_0-1679045217419.png directory.
Martin Hanák
Ok. See the attachments for ip.txt file
1.] ip.txt file does not contain physical address A8-7E-EA-E9-C6-3B (included in license file)
2.] your laptop does not have LAN connector, only WiFi network card is available
Please disable MAC randomization, reboot laptop, generate new ip.txt file and send it to me.
https://support.boingo.com/s/article/How-to-Disable-MAC-Randomization-in-Windows-10
Martin Hanák
It is turned off.
@AK_10584883 wrote:
It is turned off.
according to https://www.ptc.com/en/support/article/CS68726 article, you can:
Request for a license manually by providing Mathcad product code and physical address of network adapter using web case logger. The license file will be sent via E-mail.
Web case logger URL ... http://support.ptc.com/support/mathcad_supportCenterSingleUser.htm
Send them MAC address of your WiFi network card ... EE-43-84-7D-C6-79
Martin Hanák
Thank you. I've tried to send a request.
I presume product code is the same as licens key?
And MAC adress the same as host ID?
Attachments shows immediate respond.
it looks like your request was rejected.
Try another method ... send email to academicsupport@ptc.com
Describe your request, add Mac address and the product code.
Martin Hanák
