Can't change language in Creo Parametric 7.0
richard_kraemer
3-Newcomer
Hi, i can't seem to change the language in Creo Parametric 7.0 from english to german.
I've already tried adding the "ENV=PRO_LANG=german" line in the parametric.psf even with german language selected during installation.
I've also changed the system language with a clean install but without any results.
12 REPLIES 12
check whether your Creo installation contains directories named german, for example C:\Program Files\PTC\Creo 7.0.2.0\Common Files\text\german.
Martin Hanák
Hey,
I've checked and my directory contains german folders.
Hey,
please upload parametric.psf file located in your installation. I will check its contents.
Note: Put the file into zip-file and upload zip-file.
Martin Hanák
next tip...
Check the contents of config.pro file(s). Following options turn localization off.
dialog_translation no
help_translation no
msg_translation no
menu_translation no
Martin Hanák
Hey,
Where can I find the config.pro files?
The parametric.psf is attached.
Hey,
it seems to me that parametric.psf is OK.
config.pro locations are mentioned at then end of https://support.ptc.com/help/creo/creo_pma/r7.0/usascii/index.html#page/fundamentals%2Ffundamentals%2Ffund_five_sub%2FAbout_Configuration_Files.html%23 document (section How Creo Parametric Reads Configuration Files at Startup).
Martin Hanák
All options are turned off ("no").
set them to yes and try to start Creo.
Martin Hanák
I can't seem to change the value. I'll attach the file.
you sent me config.cdb file. You need to find config.pro file.
Martin Hanák
I have to apologize, I've looked and can't find the correct file.
I give up. I do not have no other idea.
Martin Hanák
