Cannot install creo view express when installing creo 3.0 university student edition.
gappleby
I am new to Creo and have just purchased Creo university student edition and cannot install Creo view express. When downloading the program it gives me an error message and a hyperlink that does't lead anywhere. Some help would be much appreciated.
I am also unsure if i've actually managed to download everything in the package, I am unsure if we get tutorials etc. Some description might be necessary.
This probably sounds incredibly primitive but I really do need some help..
did u find any solution?
  • unzip Creo installation zip file (4 GB)
  • go to install\addon\pvx32_64\pvexpress directory (valid for Creon 7.0)
  • install Express using CreoView_Express_64.msi
Martin Hanák
should i install it before starting the set up?
or after setup?
and should copy the setup.exe to PTC and then install?
or after setup?
I am sorry I do not understand your question properly.
... CreoView_Express_64.msi is install package of Creo View Express. You can use it on any PC to install Creo View Express.
Martin Hanák
