Completed installation with warning
JA_14071535
2-Explorer
I installed creo 11 but it stated that its installed with a warning, which is that "Creo cannot detect the supported JRE version of Java 17 on your machine or the version installed is out-of-date and not registered. Creo supports either Oracle or Amazon Corretto Java 17. If you prefer to use Oracle, PTC recommends that you install Java 17 from here. If you prefer to use Amazon Corretto, you can install Java 17 from here.".
What does this mean?
the warning you mentioned is information, only. Java is not required to common use of Creo.
Martin Hanák
