I always get "Model is not generated" conflict message when I save the assembly after using Drag Components.
Is this message informational or is this an error that I need to address? or can I ignore this message?
Creo is telling you the assembly is not fully regenerated. In this case, it does not know the location of all the components, primarily the ones you have moved with Drag Components action. In last week's Robotalk webcast, we showed how to use the Regen Value option in the assembly constraints box. This will always put your components back to a "default" location during a Regeneration action.
Selecting regenerate action on menu resolved the issue. Thanks,
