Dear ptc community, (Second request as I didn't get reaction from the first)
I tried to convert old mathcad file but the following error as shown in the screenshot below popped up ( I have a Mathcad prime 7 installed)
I also have enabled the .Net Framewor....on my windows, but I still have the same error after that as well. I really need the files for my PhD project. Can someone help me with this issue please. I attached the file so that someone can help me converting the file.
Thank you
Tadele
Hi Vladmir,
Would it also be possible for you to convert the attached old Mathcad file the same way you did? Thank you for your help already.
Kind regards,
Tadele
Thank you very much, Vladmir. I can now use my files. Would it possible for you to tell me how you did that. I can then convert it myself, if I will have a file like that.
