i was using creo wildfire 5.0 before, but now i shifted to creo 2.0 student version. The files which is created using the older version is not opening in the current version which i am using now. Recently i have downloaded few cad files from SKF ( a bearings and housing manufacturer ), even those files are not opening in my current version, since the manufacturer used a commercial version of creo. could someone please help me in converting the format of this CAD files.
Thank you
You can not use educational files on the commercial version or the other way around.
PTC can provide conversion for these files if you contact them.
