Instructions for creating Isometric and Trimetric views in Creo 2.
A Creo 2 part is attached for you to experiment with.
Creating an Isometric view
Saved Views > Front
View tab > Orientation group > Reorient
Type = Dynamic Orient
For V type -45 and press Enter
For H type 35.2644 and press Enter.
In Saved view section, type a name e.g. Iso_view and click Save then OK
Save your model with the new view
Create a Trimetric view
Saved Views > Front
In V field type -40 and press Enter
In H field type 30 and press Enter
In the Saved Views section, type a name for the view e.g. Tri_view and click Save then OK.
Save your model with the new view.
you can also reset the default view to isometric..............
1. click on named views
2. Front
3. Click on named views again and select reorient
4. Under type select preferences
5. Leave Options at model center
6. Change default orientation to Isometric
7. Click OK
I beleive this will hold for future models as well.
Kindly provide solution for Trimetric View
