Hi everyone,
I've been having this problem for a month and I have absolutely no idea how to fix it. It happens very often that when I have a .prt file or other file opened in Creo, it starts an infinite loading process that ends with the program forcefully closing. If I reopen Creo without opening the file, nothing happens, but when I open a file, it appears with a vertical black bar on the right side of the screen, starting the infinite loading process again. The only way I can fix it is to restart my PC. I checked my PC's system requirements, and they should be sufficient (I have an Asus Pro). I tried disabling Windows' antivirus, but nothing.
Thanks in advance.
it looks like graphic card driver problem.
Test following procedure:
If your problem disappears then you will have confirmed that the problem is related to graphic card drivers. You have to install "right version" of graphic card drivers.
